XR700 Periodic WAN disconnects (still) on latest v1.0.1.8
Netgear support is working with my at the moment, and I have some testing to do later tonight. Hopefully the fix will work.
- TalonteddJan 15, 2019Apprentice
ExpLiciTSainT . I am interested to know what they are having you test! Maybe send in message if you do not want to post in this thread. I am more than willing test things and give input to support team.
- ExpLiciTSainTJan 15, 2019Guide
I had to accept a EULA and I admit I didn't read it very well. I don't think there was an NDA, but it's basically a beta firmware. I just uploaded it and I am testing it now.
The beta firmware failed to work. Rolling back to the .20 version. Seems good so far.
- AltsaiJan 15, 2019NETGEAR Expert
Since beta FW does not work for you, my suggestion to you is to file a ticket to support team to check your case (without IPv6 disable), maybe arrange remote debugging or collect more debugging log to figure out what the issue is
