Leo1garcia1
Oct 15, 2023Follower
XR700 Router stopped broadcasting SSID
Anybody got a fix for 2.4 band not working but 5 band is working perfectly.
Netduma-Fraser
Oct 29, 2023NetDuma Partner
I think it is a hardware issue, apparently the normal Nighthawk equivalent suffers the same issue
iamsotorious
Oct 29, 2023Aspirant
You think it got fried when I logged into dumas? It was so weird the second I logged internet bricked.
- Netduma-FraserOct 29, 2023NetDuma PartnerI don't think it would have specifically been that, the WiFi drivers probably failed. I've not seen anyone able to recover it unfortunately.
- FURRYe38Dec 02, 2023Guru - Experienced User
Something to try and see if this might help:
https://forum.netduma.com/topic/51612-new-xr700-beta-firmware-33363/?do=findComment&comment=385598
- iamsotoriousDec 03, 2023Aspirant
i got rid of the router, to unpredictable for me. thanks though hopefully this helps someone in the future.
