Mikeclev7
Dec 25, 2019Aspirant
XR700 Router stopped broadcasting SSID/no wifi
Yesterday afternoon, my wifi stopped working. What I mean is I could no longer find the SSID, on any device, and cannot connect. When I log into the admin page, on the home page it shows the wireless ...
SonzofGod
May 17, 2020Tutor
Did you ever solve this issue? My year old XR700 suddenly started doing this yesterday.... SSID is not showing or intermittent. The WiFi radio button the front appears to do nothing....as well as the Duma OS enable radio button checkbox. Also, the router WILL NOT let me do a factory reset. The power LED just flashed white while I have the reset button pressed....never goes orange.
ALL GHz bands show disabled in the DUMA OS....
GhillieK9
Aug 19, 2020Apprentice
Did you guys ever get that resolved? I have the XR700 and suddenly WiFi radios stopped working...it's not the button...under advanced wireless they are both turned on.... it's selected to broadcast...I can only connect via Ethernet...did full reset....hard reset...factory reset....nothing works.
- Mikeclev7Aug 19, 2020AspirantNope. You know what my fix for it was though? I sent that overpriced piece of garbage back to Amazon and got a refund!
- GhillieK9Aug 19, 2020ApprenticeLol wish I could. I think the actual wifi radios malfunctioned...what did you go with instead? I'm thinking about trying ASUS one of their gaming routers.
- Mikeclev7Aug 19, 2020AspirantI was looking at the ax6000 asus. But I just went back to cox equipment because it never let me down honestly. Never had issues with ISP equipment.
