Mikeclev7
Dec 25, 2019Aspirant
XR700 Router stopped broadcasting SSID/no wifi
Yesterday afternoon, my wifi stopped working. What I mean is I could no longer find the SSID, on any device, and cannot connect. When I log into the admin page, on the home page it shows the wireless ...
Netduma-Fraser
Aug 20, 2020NetDuma Partner
GhillieK9 I would recommend re-upgrading to the latest firmware using the TFTP method as that will bypass the boot process and any issues that may be there. Would then suggest a factory reset. This will give you the freshest install possible.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
GhillieK9
Aug 20, 2020Apprentice
I will try this method and report later. FYI I have tried several other firmware....the.20.10 and.08 that hot flash one that someone suggested. But those were the regular method so I'll try this. Thank you
