Mikeclev7
Dec 25, 2019Aspirant
XR700 Router stopped broadcasting SSID/no wifi
Yesterday afternoon, my wifi stopped working. What I mean is I could no longer find the SSID, on any device, and cannot connect. When I log into the admin page, on the home page it shows the wireless ...
Netduma-Fraser
Aug 20, 2020NetDuma Partner
In the Advanced WiFi options disable the radios, apply then reboot. Then go back, enable, apply and reboot again. See if that helps bring them back to life.
GhillieK9
Aug 20, 2020Apprentice
Let me try that....I never did.the reboot when I toggled them before...good idea
