OlegP
Sep 05, 2019Apprentice
ReadySHARE not working with Windows 1903
So I've had 1903 upgrade install itself on all of my Win 10 machines at home and it has killed the ReadyShare utility on all of them. It will not display a USB printer anymore when I launch the u...
OlegP
Sep 22, 2019Apprentice
Any news about the Windows print share utility or can someone from Netgear tell when it'll be available to be used on the latest Windows build? I'm surprised that it's taking so long since 1903 has been out out for a while and surely I'm not the only one that has encountered this issue by now.
Thanks
Sladner84
Oct 03, 2019Guide
I cant seem to get ReadySHARE to work anymore either... have we figured out a solution yet?
- Netduma-FraserOct 05, 2019NetDuma PartnerHi Sladner84, you have a different router so it would be best if you posted in the Nighthawk WiFi router section if you're having issues.
- Sladner84Oct 05, 2019GuideI was able to get it working :)
