OlegP
Sep 05, 2019Apprentice
ReadySHARE not working with Windows 1903
So I've had 1903 upgrade install itself on all of my Win 10 machines at home and it has killed the ReadyShare utility on all of them. It will not display a USB printer anymore when I launch the u...
Sladner84
Oct 03, 2019Guide
I cant seem to get ReadySHARE to work anymore either... have we figured out a solution yet?
Netduma-Fraser
Oct 05, 2019NetDuma Partner
Hi Sladner84, you have a different router so it would be best if you posted in the Nighthawk WiFi router section if you're having issues.
- Sladner84Oct 05, 2019GuideI was able to get it working :)
