ackkca
May 12, 2020Aspirant
Readyshare sharing violation with MacOS Excel on a XR500
Nighthawk XR500 V2.3.2.56 DumaOS MacOS 10.15.4 Mac Office 365 Excel v16.36 When ever I save a .xlsx Excel file on a Mac to my XR500 Readyshare network volume, I get a sharing violation and a c...
Netduma-Fraser
May 12, 2020NetDuma Partner
Is it specifically that excel format? If you try a docx for example do you get the same issue?
- ackkcaMay 13, 2020Aspirant.docx worked fine in Word.I went thru all of the Excel file formats and found all the following gave the sharing violation error..xlsx.xltx.xlsm.xlsb.xltm.sltmAll the other Excel file formats work fine.
- Netduma-FraserMay 13, 2020NetDuma PartnerI have no idea why that could be, perhaps make a ticket with Netgear. Meanwhile though, zip the file which will take 2 seconds extra then you should be able to share it.
