Nelinski
May 05, 2020Aspirant
ReadyShare Storage - Some Folders Get Error "Location is not available" - Windows 10 - XR700
I'm wondering if someone can point me in the right direction. I've tried setting up an NTFS drive with ReadyShare. For some reason, I can't access some folders/files but I can access others on Window...
Netduma-Fraser
May 05, 2020NetDuma Partner
It may help to open a ticket with NG directly by signing in here while we try to help: http://support.netgear.com/
Could you provide a screenshot of the ReadyShare Storage page please.
Nelinski
Hi Fraser,
This is the ReadyShare page (see attached).
- Netduma-FraserMay 05, 2020NetDuma PartnerIt seems like you've enabled only admin to use it but haven't enabled Admin password protection for the network neighborhood, enable that and see if it works.
- NelinskiMay 05, 2020Aspirant
Tried that already unfortunately. Also tried it with no passwords at all. Still the same issue.
- Netduma-FraserMay 05, 2020NetDuma PartnerIn your Windows 10 Advanced Sharing Options do you have file and printer sharing on? You will need that set first if you don't.
