Nelinski
May 05, 2020Aspirant
ReadyShare Storage - Some Folders Get Error "Location is not available" - Windows 10 - XR700
I'm wondering if someone can point me in the right direction. I've tried setting up an NTFS drive with ReadyShare. For some reason, I can't access some folders/files but I can access others on Window...
Nelinski
Hi Fraser,
This is the ReadyShare page (see attached).
Netduma-Fraser
May 05, 2020NetDuma Partner
It seems like you've enabled only admin to use it but haven't enabled Admin password protection for the network neighborhood, enable that and see if it works.
- NelinskiMay 05, 2020Aspirant
Tried that already unfortunately. Also tried it with no passwords at all. Still the same issue.
- Netduma-FraserMay 05, 2020NetDuma PartnerIn your Windows 10 Advanced Sharing Options do you have file and printer sharing on? You will need that set first if you don't.
Yup. That's enabled too. I've spoken with Netgear on the phone (just got off now) and they've taken some logs to look into it further. Guessing it's a weird issue nobody knows how to solve!
