schumaku
Jan 28, 2019Guru - Experienced User
ReadyShare USB Storage Service Announcement by WS Discovery?
Can any XRxxx owner confirm there is (or is no) WS Discovery for the ReadyShare service (to access the USB storage by SMB protocol)? I suspect Netgear is here stuck on NetBIOS continuously requiring ...
Running Windows 7 and having a USB drive connected and enabled and ReadyShare enabled on my XR450 router:
I get this result
XR450 Ready ShareNetworking DetectedUSB Contents
Netduma_Jack
Jan 29, 2019NetDuma Partner
Hi - this is probably one for TimChang to help with as ReadyShare etc. is handled in the NETGEAR firmware. Sorry we can't be more help.
- timc0928Jan 29, 2019NETGEAR Expert
There is no WSD server running in our router.
Our Router relies on SMB 1/CIFS to discover the devices, if SMB 1/CIFS is disabled in windows 10, You cannot see READYSHARE in windows 10. (You should still can use Windows explorer access readyshare via \\Your Router IP address)
In windows 7, SMB 1/CIFS is enabled, so it can be discovered (possibly by netbios provided by the samba server in our router).
- Netduma_JackJan 30, 2019NetDuma Partner
Thanks Tim!
