scifi3dzoo
Nov 04, 2021Tutor
Reboot remotely possible??
OMG I had this great idea to connect it to a smart plug. Then I figured out I can turn it off but not back on. Yikes. You can log in via 192.168.0.1 etc etc. but that only works from home on your ...
Netduma-Fraser
Nov 04, 2021NetDuma Partner
You can try the app or enable remote management in settings, then connect using your public IP address (instead of the normal LAN IP you would use) then reboot from the interface that way
scifi3dzoo
Nov 04, 2021Tutor
u know much about "remote management"? I tried it. so go to phone and type in the
typed it into my phone browser just like that and it does nothing.
- scifi3dzooNov 04, 2021Tutor
**bleep**... I got it. had to disconnect phone from my network. I didn't think that would matter.
- Netduma-FraserNov 04, 2021NetDuma PartnerYep you got it!
