TheBroheim
Jan 22, 2022Aspirant
Recently setup Nighthawk XR1000 and my phone and chromecast are having issues with certain apps
Router is Nighthawk XR1000 with latest firmware 1.0.0.58_1.0.44. Every device on our network works correctly on this new router, except for my Google Pixel 6 phone and Chromecasts. My Pixel 6 can...
- Jan 24, 2022I have found a solution. Ticking "use as wireless access point" has worked. Not sure why that would prevent certain aspects of android OS to not load anything. But it is now working perfectly.
Netduma-Fraser
Jan 22, 2022NetDuma Partner
Interesting, not seen this before, in WAN Settings can you toggle IGMP Proxying and set NAT to Open and see if that helps please?
- TheBroheimJan 24, 2022AspirantI have found a solution. Ticking "use as wireless access point" has worked. Not sure why that would prevent certain aspects of android OS to not load anything. But it is now working perfectly.
- plemansJan 24, 2022Guru - Experienced User
TheBroheim wrote:
I have found a solution. Ticking "use as wireless access point" has worked. Not sure why that would prevent certain aspects of android OS to not load anything. But it is now working perfectly.if its running in access point mode, you're not using a simple modem. You're gateway has its own integrated router.
It causes a double nat. Not all devices play nicely with a double nat.
but putting your gaming router in access point mode, removes half the benefits of having a gaming router.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode - Netduma-LiamJan 25, 2022NetDuma Partner
Running the XR1000 as an AP isn't a great solution I'm afraid, you're losing all features of DumaOS by doing this.
Take the XR out of AP mode and instead completely disable QoS from the three-line menu in Congestion Control. If that resolves the issue, we've narrowed down the problem to QoS. If not, we can troubleshoot elsewhere.
