TheBroheim
Jan 22, 2022Aspirant
Recently setup Nighthawk XR1000 and my phone and chromecast are having issues with certain apps
Router is Nighthawk XR1000 with latest firmware 1.0.0.58_1.0.44. Every device on our network works correctly on this new router, except for my Google Pixel 6 phone and Chromecasts. My Pixel 6 can...
- Jan 24, 2022I have found a solution. Ticking "use as wireless access point" has worked. Not sure why that would prevent certain aspects of android OS to not load anything. But it is now working perfectly.
Jan 23, 2022Guru - Experienced User
what modem/gateway are you connected to ?
Are you using IPv6? If so, did you change the IPv6 DNS server as well? or just the IPv4?
