That_GamerYT
Feb 10, 2021Apprentice
Recommended switch for gaming?
What unmanaged switch is good for gaming with the XR500? I've heard these are good: GS308 •Black color matches XR500 and other computers in my home •3 year limited hardware warranty •Fanless a...
- Feb 16, 2021If port 1 is the WAN port in that scenario then yes absolutely they will appear as though they are connected to the router and the router sees it that way too - as you put, just like having more ethernet ports.
Netduma-Fraser
Feb 10, 2021NetDuma Partner
If you want an unmanaged switch then it doesn't matter - they're sometimes referred to as a 'dumb' switch as all they do is pass traffic through. So literally anyone will do if it can handle your speeds.
