That_GamerYT
Feb 10, 2021Apprentice
Recommended switch for gaming?
What unmanaged switch is good for gaming with the XR500? I've heard these are good: GS308 •Black color matches XR500 and other computers in my home •3 year limited hardware warranty •Fanless a...
- Feb 16, 2021If port 1 is the WAN port in that scenario then yes absolutely they will appear as though they are connected to the router and the router sees it that way too - as you put, just like having more ethernet ports.
That_GamerYT
Feb 16, 2021Apprentice
So when you say "pass traffic through", you mean I can manage the devices connected to it from the router? So for example, If I plug in the router to port 1 on GS308 and I have my PC in port 2, PS4 in port 3, TV in port 4, etc., they will appear on LAN in the device manager and they will appear in hybrid VPN for me to manage? Basically is it just like as if the router has more ethernet ports from the unmanaged switch?
Netduma-Fraser
Feb 16, 2021NetDuma Partner
- That_GamerYTFeb 16, 2021Apprentice
Ight bet.
- randomkhed101Feb 26, 2021Star
So wil QOS stil werk for bandwidth alocaytion and trafic prioritisation?
- Netduma-FraserFeb 27, 2021NetDuma PartnerYes as the router sees them as directly connected it is able to apply those features to the devices.
