That_GamerYT's avatar
That_GamerYT
Apprentice
Feb 10, 2021
Recommended switch for gaming?
What unmanaged switch is good for gaming with the XR500? I've heard these are good:   GS308 •Black color matches XR500 and other computers in my home •3 year limited hardware warranty •Fanless a...
  • Netduma-Fraser's avatar
    Netduma-Fraser
    Feb 16, 2021
    If port 1 is the WAN port in that scenario then yes absolutely they will appear as though they are connected to the router and the router sees it that way too - as you put, just like having more ethernet ports.
