ClintonHen
Jul 13, 2020Follower
Recommended Wifi Settings for Nighthawk XR500
Hi What are the recommended WIFI settings to keep the Wifi signal stable?
Netduma-Fraser
Jul 14, 2020NetDuma Partner
I would recommend disabling Smart Connect and connecting devices to 2.4 or 5GHz manually. Then use a WiFi analyzer (should be able to find a free one) and find the least congested channels in your area and change to those.
