Phayt
Aug 06, 2019Tutor
RED blinking Ethernet port lights.
My Router (R9000 (4MY16A5900AD7)) has been working great for a year or so. I was gaming on a rather hot day and suddenly lost connection. When I checked the Router, the ethernet light was blinking R...
Aug 06, 2019Guru - Experienced User
What is the Mfr and model# of the ethernet switch if one is in the configuration.
Try a factory reset on the XR router. Power OFF the ISP modem for 30 seconds then back ON. Disconnect the switch from the XR router. Walk thru the setup wizard with a wired PC.
Do you get any WHITE leds after this?
Netduma-Fraser
Aug 06, 2019NetDuma Partner
You may get more specific answers if you post your topic here https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk as that is the forum for your type of router.
- PhaytAug 06, 2019Tutor
Thank you, reposted.
