Gimli
May 13, 2018Tutor
Red led
Hello everyone!!!!! I live in Brazil and my router arrived, I connected my pc in it, but when connecting a second device, in the case of my receiver, the led of the router turns red, in case the lig...
Gimli
May 13, 2018Tutor
Are there any problems with leaving the device connected to the router?
Netduma-Fraser wrote:
It means you're using an ethernet cable that's limited to 100mbps or the device itself is limited to that speed
Netduma-Fraser
May 13, 2018NetDuma Partner
No problems, as I say just means device won't be able to reach over 100mbps.
