seroo
Nov 10, 2024Aspirant
reduce Latency on a Three: 5G BB Unlimited hub with nighthawk
i know gaming on a 5g router increase latency/ping, i was wondering if anyone knows if this can be reduced by a gaming router?
Nov 11, 2024Guru - Experienced User
Also be sure that the higher ping and latency isn't coming from the ISP side.
Run a a test with a wired PC connected directly to the ISP modem or ONT using Pingplotter app.
