SturmButcher
Mar 30, 2019Aspirant
Region Lock how to change it FW version 2.3.2.40
I am from Chile(South America), I searched in the forums how to change the Region Lock but I didnt undertand how to do it via telnet.... the router was bought through Amazon.com, I have been facing a...
SturmButcher
Apr 02, 2019Aspirant
as schumaku said it will not work perfeclty, in fact I have heavily disconnections on my wifi every day, which is really bad...I cant return the product because I have to pay the shipping which cost much more than the product itself, you should provide a firmware for south america because lock in it is not good for consumers, specially if you sell trough amazon and they sell it worldwide...
schumaku
Apr 02, 2019Guru - Experienced User
Again, I'm not Netgear, so I don't know how and if Netgear does business in the South Americas. Some countries like Brazil are very difficult to deal with, putting up extremely high taxes on the products, unless some major parts of the production and the assembly in done within the country.
As I mentioned before, most world-wide markets receive wireless model variants with worldwide code inside (the firmware is the same - the details are taken from the product factory config!) so the legislation (== country of deployment) can be selected.
- Netduma-FraserApr 02, 2019NetDuma PartnerI'd suggest you contact Netgear directly here: http://support.netgear.com/ by creating a ticket or through phone. Explain the issue you're having and they should be able to guide you through changing your region via Telnet.
- schumakuApr 02, 2019Guru - Experienced User
Netduma-Fraser wrote:
Explain the issue you're having and they should be able to guide you through changing your region via Telnet.Strongly doubt they will do ... it's a well protected secret.
