WacoJohn
Nov 05, 2024Luminary
Replaced dead XR500 with new one. No option to create//restore netgear_xr500.cfg
model xr500 firmware Not sure, Check for new ver does not install anything newer DUMA V2.3.2.134 There are instructions in a help article how to back up/restore router's configuration.It must hav...
- Nov 05, 2024I think you're still trying to get it from the settings on the top right.
It's the actual settings page - Settings > Administration > Backup Settings
If not please provide a screenshot of the options available
Netduma-Fraser
Nov 05, 2024NetDuma Partner
You need to go to Settings first and it'll be there in a sub menu
- WacoJohnNov 05, 2024Luminary
Settings
router admin not there
Language not there
accessibility not there
advanced <<<<<<<<< not there
- Netduma-FraserNov 05, 2024NetDuma PartnerI think you're still trying to get it from the settings on the top right.
If not please provide a screenshot of the options available- WacoJohnNov 07, 2024Luminary
Yea Sir, You are entirely correct. Took your route and there it all is.. NOT from upper right corner, You are the best, and thank you immensely for all you do.
