KHdV1966
Nov 14, 2020Tutor
Replacement antennas for XR500
I lost my antennas while moving to my new house. Is it possible to replace them and where can i sell them? I have been lookin around the internet en at the netgear support site but can not find anyth...
Nov 14, 2020Guru - Experienced User
The xr500 uses RP-SMA connections. any 2.4g/5gh antenna should work to replace them. there's a bunch on amazon.
Netgear doesn't sell replacement antennas.
shouldn't have said "any". You just need to make sure the plug connector is long enough so you can angle the antenna's. Some come with shorter connections.
- KHdV1966Nov 14, 2020Tutor
Yes thats the problem. I need at leas 30mm before the antenna bend upwards
- plemansNov 14, 2020Guru - Experienced User
You could always cheat with something like this:
https://www.amazon.com/Eightwood-Antenna-Connector-Magnetic-Wireless/dp/B07JVDNDCR
- KHdV1966Nov 16, 2020Tutor
I have an Netgear R7500 router. Are these antennas compatable withe the XR500? If so, then I can use that ones.
- plemansNov 16, 2020Guru - Experienced User
I don't have either. All you can do is try.
