Tkbuc
Nov 27, 2022Guide
Reset to Factory Default after every firmware update?
I read somewhere that it is recommended to factory reset the XR1000 Pro Gaming router after every firmware update? Is this true? I am thinking of factory reset because my 2.4G band sometimes wont a...
Nov 27, 2022Guru - Experienced User
