robturpin's avatar
robturpin
Apprentice
Jun 18, 2024
Router and switch connections
I use a XR1000 router and a GS108v4 unmanaged switch, and I'd like to know if I can (without problems) and should (would get speed/routing benefits) connect them using more than one Cat6 Ethernet cab...
  • robturpin's avatar
    Jun 18, 2024
    I've read about a "packet storm" which is caused by a loop which is exactly what I believe would happen if I connect a router and a unmanaged (dumb) switch together using more than one cable.
