Sp4
Mar 31, 2020Guide
Router Config Compatibility
I am upgrading from a R8000 to a XR500. Is the config file for the R8000 able to be applied to my new XR500?
- Mar 31, 2020
No you shouldn't transfer config files to different routers, they both use completely different software so would not be advisable.
Netduma-Fraser
Mar 31, 2020NetDuma Partner
Sp4
Mar 31, 2020Guide
Thank you for the quick response!
