DuGo2Guy's avatar
DuGo2Guy
Router Configuration
Is there any detailed Doc, other than Man Doc that came with my Unit that details router capabilities. That is, before I go and destroy my working standard configuration by not understanding the consequences of one or another check box, is there any elaborating Doc. Example, I know what a DMZ is, but within the Netgear family routers, if I start messing with this configuration is it in conjunction with my standard WAN/LAN configuration or exclusive of it. As with MS, which is like reading War and Peace, there's a lot of "you Cans but available Doc falls short of "This is what you are physically doing".
