jmreeves1982
Sep 24, 2020Aspirant
Router consistently rebooting daily
I have only had this router for about a week now. Every day between 5pm to 8pm local time for myself. The lan ports stop working. The router is plugged directly into the wall, not a powerstrip agai...
Sep 25, 2020Guru - Experienced User
Is it only the lan ports that stop working?
Does wireless go down at all?
Does it reboot during this time?
Have you tried it on a different outlet?
Or tried a factory reset and reinstall of it?
jmreeves1982
Sep 25, 2020Aspirant
I have tried two different outlets as well as the power strip that my computer and peripherals are plugged into.
Both wireless and wired connections go down
I will do a factory reset shortly to test.
Currently at work so the response may be a few hours in regards to this.
