ArchAngel0138
Apr 06, 2019Tutor
Router Dropping Internet Connection
Morning,
I have owned the XR500 for about 8 months. It was running beautifully and now it continuously drops the internet. This happens to everything that is connected via wifi. (I cant connect...
Netduma-Fraser
Apr 07, 2019NetDuma Partner
Okay keep us updated with what you find!
ArchAngel0138
Apr 10, 2019Tutor
It worked for about 48 hours and has started doing it again. Not sure what else to do now. My wife works from home so this is a super inconvenient problem. I always have top of the line anti virus and security. I’ve checked firewall security settings etc and nothing there should be messing with the routers WiFi. Please let me know if you have any ideas other than what I listed in the original post
