ArchAngel0138
Apr 06, 2019Tutor
Router Dropping Internet Connection
Morning,
I have owned the XR500 for about 8 months. It was running beautifully and now it continuously drops the internet. This happens to everything that is connected via wifi. (I cant connect...
Apr 10, 2019Guru - Experienced User
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Try enabling Beamforming and MIMO and WMM. Set 20/40Mhz Coexistence to 40Mhz only.
Netduma-Fraser
Apr 10, 2019NetDuma Partner
Possible that because of auto upgrade it's upgraded you onto a firmware that's caused the issue. Try downgrading to this firmware and see if it performs better https://kb.netgear.com/000060127/XR500-Firmware-Version-2-3-2-32
- ArchAngel0138Apr 10, 2019TutorWill give that a shot too, thank you! Will post again once I run through both of yalls suggestions.
