Kirkanos5089
Oct 30, 2018Aspirant
Router hasn't been the same since DoS attacked
So my friends and I were playing Call of Duty on Xbox One. We were trying our hearts out and won against them 2 games in a row, in the middle of the third one of the group began DoS'ing us. Two of my...
Kirkanos5089
I've already rebooted the router 5 times since last night but I'll probably try it again if it persists through tomorrow. Any other tips?
Oct 31, 2018Guru - Experienced User
Try a factory reset and setup from scratch.
What is the Mfr and model# of the ISP modem?
- Netduma-FraserOct 31, 2018NetDuma PartnerI'll explain the Geo-Filter issues you've encountered as I'm not sure they're issues that would have arised from an attack.
The Geo-Filter can't prevent other players joining certain servers, it can only make sure you connect to the closest server which gives you an advantage as you have the lower ping to the server. Could also be a server just classified as a peer that we'd need to update. Can check if you like by doing an IP lookup on the domain name. The disconnect from Xbox parties could be because you need to add your friends to your allow list.
A factory reset would not be a bad idea in this instance to ensure theres no lasting affects from the attack.
