UTLEYM
Mar 09, 2021Aspirant
Router keep dropping LAN connection with XBOX series X
For whatever reason, this router keeps dropping LAN connection. I have 1 gig internet. I have no idea what is going on.
jonbusinessacct
Mar 10, 2021Aspirant
This was plauging me for several months and I found it was Netgear's security software. 10x speed improvements once these fixes were enabled.
Advanced Setup
Disable QOS
Disable Port Scanning and DOS Protections
Respond to Ping on Internet Port
Disable IGMP Proxying
Disable SIP ALG
UTLEYM
This didn’t work. Thank you for the recommendation though!
