UTLEYM
Mar 09, 2021Aspirant
Router keep dropping LAN connection with XBOX series X
For whatever reason, this router keeps dropping LAN connection. I have 1 gig internet. I have no idea what is going on.
UTLEYM
Mar 10, 2021Aspirant
Additionally when I open the interface I get a huge question mark in the middle and I can’t change settings.
Netduma-Liam
Mar 11, 2021NetDuma Partner
Do you get that question mark when you try to access the interface during a drop or is it all the time? What firmware version are you currently running?
- UTLEYMMar 11, 2021AspirantYeah, I reset the device when I got home and everything worked perfect. As soon as the drop occurred and I tried to get on and mess with the settings I get that massive question mark. Whatever the latest update was. I’ll have to check when I get home.
- Netduma-FraserMar 11, 2021NetDuma PartnerDo you have an Adblocker on the web browser? If so then please disable that and it should appear correctly. Otherwise clear your browser cache/cookies and try again.
- UTLEYMMar 11, 2021AspirantStill doesn’t change the fact it drops lan connection.
