UTLEYM
Mar 10, 2021Aspirant
Router keep dropping LAN connection with XBOX series X
For whatever reason, this router keeps dropping LAN connection. I have 1 gig internet. I have no idea what is going on.
UTLEYM
Mar 12, 2021Aspirant
Still doesn’t change the fact it drops lan connection.
Netduma-Liam
Mar 12, 2021NetDuma Partner
Sure, but has that resolved the issue with the interface displaying? Once we've resolved that it'll be easier to troubleshoot the disconnections. Did you find out what firmware you are running?
- DraamaApr 24, 2021Aspirant
im having this exact same problem it just drop connection sometimes about 15 times in an hour and stops each drop lasts about 10-30 seconds idk what it is anymore :(
- Netduma-FraserApr 24, 2021NetDuma PartnerDraama I'd recommend you post here for your router: https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
