RadenBlazed
May 23, 2019Aspirant
Router keeps loosing all internet connection.
I have a XR500 router and a CM1000 modem... I have a few thing hard wired and the rest is on wifi. threw out the day I just randomly lose internet. I can still see everything connected to my router bu...
RadenBlazed
May 27, 2019Aspirant
doing the firmware update has not fixed it. actually it apears to have made it worse. now instead of only dropping out a couple times a day. it apears to do it about once every hour or so.... ... pls help
May 27, 2019Guru - Experienced User
Did you down grade to v32 and also perform a factory reset and setup from scratch after applying v32?
- RadenBlazedMay 27, 2019AspirantI have been doing resets every time I do a firmware update. Ill try 32 and see if that works
- FURRYe38May 27, 2019Guru - Experienced User
RadenBlazed wrote:
I have been doing resets every time I do a firmware update. Ill try 32 and see if that works- RadenBlazedMay 27, 2019Aspiranti wrote the moddle on the first post. its a netgear cm1000
