mikes_17
Mar 22, 2021Tutor
Router keeps rebooting itself
Hi there My Nighthawk XR500 keeps rebooting itself for no apparent reson. I have the latest firmware installed and i know its not an electrical issue as i am an electrician by trade and have had a ...
mikes_17
Mar 23, 2021Tutor
Since uploading post i have had it happen again. Looked at router logs and noticed this.
again any help would be great
- Netduma-FraserMar 23, 2021NetDuma PartnerCould you try upgrading to the latest beta firmware available here please: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/New-Firmware-v2-3-2-120-XR500/m-p/2075041
Then do a factory reset and see if it is more stable- mikes_17Mar 23, 2021TutorAwesome thanks will definitely look into that. I ended up installing an earlier firmware version which I think has temporarily solved the problem but is only a short term solution
