Daggerz
Jun 14, 2018Follower
Router Login by name
On some routers like the last one I had, I was able to name my router so that I could then just type the name of it in my internet browser's address bar and go to my router's setup page. I have tried looking on this router and thought I found where to do that (I did change my device name), but I am not able to access my router by the device name. Is this something that is possible with this router?
Basically I am wanting to know if I can assign a name like 'Monkey' and access the router my typing 'monkey' into my browser instead of routerlogin.net.
Thank you.
Im afraid not you have to type that or the IP its on, the default is 192.168.1.1 but that can be changed of course, you cant give it a name lthough.
- KillhippieProdigy
- BIG_DOGLuminary
As has been said above, you cannot do what you want. You could just add the router login to your bookmarks and access it within 2 mouse clicks!
- KillhippieProdigy
You can indeed, I tend to just type it in for added security as I dont want my browser remembering the login, thats my bit of paranoia online but the option BIG_DOG gives works works fine.
