suze
Mar 26, 2020Aspirant
Router Nighthawk XR500 Antenna
Hello, I've lost one antenna for this router. I have been searching everywhere, and lost hope to get it. So if U have this antenna from broken router or any ideas, Plz help me. I want to buy it. P...
suze
Oh i didint write this before, but antenna 3, like antenna 2 have a extra long plug. Its need to go inside cover of router and have 3.2cm plug.
Look at photo.foto
Netduma-Fraser
Mar 26, 2020NetDuma Partner
Christian_R DarrenM any advice?
- suzeMar 30, 2020Aspirant
@Christian_R @DarrenM .@Netduma-Fraser
any more advice?I had one more question about XR500 Mesh. I had Asus rt-ac5300 also, and want to use it like an extender (repater) in mesh, to have one name of wifi etc. Can i do it? and if i can where ill find option in xr500 (on rt-ac53- Netduma-FraserMar 31, 2020NetDuma PartnerIt's a hardware issue and we (Netduma) just created the software so I couldn't help with that unfortunately. You would have to look for that option on the Asus not the XR500 so it depends on whether that supports it. Otherwise you could put it in AP mode but it would have a different SSID, you could change it to match the XR500 and that should work in theory.
