Joeee
May 09, 2020Tutor
Router settings
I just recieved my nighthawk today and in the router settings some options are blank on the left hand side. I'm unsure why?
May 09, 2020Guru - Experienced User
Are you running in Router mode? Or access point mode?
Access point mode disables many features.
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
Joeee
May 09, 2020Tutor
I am running in access point mode any way I can ungray them?
- plemansMay 09, 2020Guru - Experienced User
No, in access point mode the primary router (not the AP) is handling those tasks.
You'd need to put the primary device in modem only/passthrough mode and reactivate the router mode on the netgear device to get them back.
- JoeeeMay 09, 2020Tutor
My router im using is a modem router so i've change it from a access point to a router in the settings now struggling to find the router IP
Joeee wrote:My router im using is a modem router so i've change it from a access point to a router in the settings now struggling to find the router IP
Ok, we need some details.
1. What modem/router are you using?
2. What netgear router?
3. firmware on the router?
which way do you have it running:
A. combo device (in modem only mode)--------->netgear router (router mode)
B. Combo device (in router mode)----------Netgear router (access point mode)
Anytime you change the combo devices mode, reboot both the modem and the router. power both off, power up the modem, give it a few minutes to fully boot, then boot the router and give it a few minutes.
