shawnn007
Jul 07, 2018Initiate
Router to work with TCL Roku enabled TV
Hello,
I am trying to set up my new XR500, it is some what slow on most my wifi devices ( phones, tv's, ect non gaming devices) but they do work. My main problem currently is that when I have ...
Netduma_Jack
Jul 08, 2018NetDuma Partner
Hi Shawn - what is the make of the modem your XR500 is plugged into? If it’s a modem/router combo, it’s possible you have double NAT.
The best thing to do is go on your modem/router and enable ‘Bridge mode’ or ‘modem mode’
What’s the exact error message you are getting on Roku?
Also, can you connect it directly to your modem? If yes, does it work?
