wolftiger21
Sep 26, 2020Tutor
Rural Gaming Questions
Hello, Moving to a new home with only cellular for internet. Will any of the netgear gaming router work in this situation? Or Suggestions for a setup? If not direct to the netgear, I worry about the...
- Sep 26, 2020You would need to use it with a router that accepted a SIM card for internet. You will be able to use them together and eliminate a double NAT while getting the best connection possible.
wolftiger21
Sep 26, 2020Tutor
Thank you!
Netduma-Fraser
Sep 27, 2020NetDuma Partner
You're welcome! If you decide to get a Pro Gaming router do post back here and we can help you resolve the NAT.
- wolftiger21Sep 27, 2020TutorWill do!
