armyguy83
Jan 21, 2021Aspirant
RX300 Geo Filter not working(I think)
So, I recently bought the Netgear RX300 from Walmart to help with getting a lower ping and better lobbies. I'm currently stationed in Hawaii and I only play Warzone. Problem is, when I try to get ...
Netduma-Fraser
Jan 21, 2021NetDuma Partner
Could you provide a screenshot of the entire Geo-Filter page please showing what you see when you're in a game? Then I can see what is happening to cause that. The Nil issue is something we're aware of and will fix in the next update - in some cases reupgrading to the same version and doing a factory reset can resolve it.
- armyguy83Jan 21, 2021Aspirant
- Netduma-FraserJan 21, 2021NetDuma PartnerOkay so I'd suggest doing the re-upgrade and factory reset to see if the Nil issue goes away. Then disable Ping Assist - put 0 for the option in the Geo-Filter Map. The Auto Ping isn't actually showing your ping so I don't think it will be that high. What firmware are you on?
