Eribos_
Nov 29, 2018Tutor
Rx700 internet drops, bad packet loss
Hello everyone, Any help is greatly appreciated. I've have researched as much as I think I can at the moment for trouble shooting the rx700. I have already updated the firmware. The WiFi is pretty mu...
Nov 29, 2018Guru - Experienced User
Is Smart Connect enabled?
What WPA security modes are you using?
Is Beamforming Enabled? MiMo?
What FW version is currently loaded?
Eribos_
Nov 29, 2018Tutor
I will look and try this tonight when I get home. Thank you for the info.
I have 3 other neighbors with WiFi.
- FURRYe38Nov 29, 2018Guru - Experienced User
Do also see issues when testing wired with packet loss?
- Netduma-FraserNov 29, 2018NetDuma PartnerAlso can you give us an idea of what speeds you pay for and if you've put them into Anti-Bufferbloats settings? An often overlooked cause is the ethernet cables, are they old? If so they could be faulty.
- Eribos_Nov 29, 2018TutorNetduma-Fraser, I'm currently going through xfinitywith 400mbps DL / 10mbps UL. I have not put them into Anti-Bufferbloats. all my cables are under a year old and look good.
Yes I still have packet loss when wired.
