Eribos_
Nov 29, 2018Tutor
Rx700 internet drops, bad packet loss
Hello everyone, Any help is greatly appreciated. I've have researched as much as I think I can at the moment for trouble shooting the rx700. I have already updated the firmware. The WiFi is pretty mu...
tonyw009
Feb 27, 2019Aspirant
my internet become slow after change to xr700, my old asus ac5300 don't have problem, but with the nighthawk i cant even use discord.
Feb 28, 2019Guru - Experienced User
What FW is currently loaded?
What speeds do you pay for UP and Down?
Speed testing with a wired PC or Laptop?
- tonyw009Feb 28, 2019Aspirant
what is FW?
my modem model is: ARRIS DG2460A
the router xr700 is connected directly to the modem
download speed 600mb, upload speed 10mb
speed test using wired PC, cable CAT8
My pc:
Windows 10 PRO
Nvidia TItan XP collector edition
Intel i7 6900k
32GB RAM
motherboard msi x99 gaming pro carbon
power supply 1200watt
try update the firmware and downgrade, but still slow internet, that doesn't happen with my old asus ac5300
- FURRYe38Feb 28, 2019Guru - Experienced User
FW = Firmware
Your ISP modem has a built in router and wifi already:
https://www.arris.com/globalassets/resources/data-sheets/dg2460_ds.pdf
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.Might downgrade to v20 as others reported this solved there problems. Recent FW seems to have problems.
tonyw009 wrote:
what is FW?
My pc:
Windows 10 PRO
Intel i7 6900k
32GB RAM
- Netduma-FraserFeb 28, 2019NetDuma PartnerHave you entered your correct speeds into Anti-Bufferbloats options in QoS? Do you have Anti-Bufferbloat enabled and Bandwidth Allocation with share excess off? If you disable QoS in Anti-Bufferbloats options do you get your expected speeds?
