TwtichStormTv1
Jul 11, 2020Follower
rx700 router
i have xifinity cox cable router. So i bought this nighthawk rx700 so i dont get ddos anymore from people when i play xbox. my question is how do i set it up? Do i remove my xfinity router or do i ha...
Netduma-Fraser
Jul 11, 2020NetDuma Partner
Yes connect it directly to the Xfinity router. If you want to prevent being DDoSed then you will need to get a VPN subscription to use with the Hybrid VPN feature and then apply it to your console.
