Gimli
May 24, 2018Tutor
Security router xr500
Hello there came a news that malware called VPNFiter infected routers in 54 countries and some brands including netgear appears as affected. I wonder if netgear is aware of the fact?
Thank you
- May 26, 2018
The list of affescted routers from Netgear from the Talos list for VPNFilter malware is below, the XR500 is not on that list.
DGN2200
R6400
R7000
R8000
WNR1000
WNR2000
Netduma-Fraser
May 25, 2018NetDuma Partner
Hi Gimli, I am sure they are aware but not sure about their next steps. We (Netduma) are testing our VPN Hybrid solution right now though.
Gimli
May 25, 2018Tutor
Mine is in the latest version and remote management was already disabled, and as soon as I got the router for the first time already I changed the password.
Can I use it without worry, or change the router for another until I find the final solution?
thank you
