CCoelho
Apr 13, 2024Aspirant
Set up nat OPEN XR 1000 PS5
Hi, I was wondering if there is a user guide or video on how to set up nat open with the xr1000 and ps5. I havent been able to figure this out or find an guide.
Netduma-Fraser
Apr 14, 2024NetDuma Partner
One is doing processing of your packets, the other isn't. However, that big difference indicates you've not fine tuned your QoS/Geo-Filter settings as much as possible. Experiment with that and you'll get a better ping.
CCoelho
Apr 16, 2024Aspirant
Ive completely turned off the QOS and im averaging around 26-28 ms vs 16-18 ms with a nat 1 connection.
As an asside, Ive given my router a static IP, added that IP to the router DMZ and Opened UPNP. Ive also ensured NAt open option is- OPEN on the router.
Im still with a nat 2 connection.
