CCoelho
Apr 13, 2024Aspirant
Set up nat OPEN XR 1000 PS5
Hi, I was wondering if there is a user guide or video on how to set up nat open with the xr1000 and ps5. I havent been able to figure this out or find an guide.
CCoelho
Apr 16, 2024Aspirant
Ive completely turned off the QOS and im averaging around 26-28 ms vs 16-18 ms with a nat 1 connection.
As an asside, Ive given my router a static IP, added that IP to the router DMZ and Opened UPNP. Ive also ensured NAt open option is- OPEN on the router.
Im still with a nat 2 connection.
Netduma-Fraser
Apr 18, 2024NetDuma Partner
The ping difference is likely because you only have the one device using the network in that scenario, no other devices using the internet when connected through the router. You'd need to fine tune your QoS settings to address that when using the router. It's not the NAT Type 1 causing it.
As above, you will not get NAT Type 1 connected to a router. It is not physically possible. You can ONLY achieve a NAT Type 1 when directly connected to a modem/ONT.
