G4Captain
Jul 19, 2018Star
Setting up a static route.
So I'm trying to set up a static route for my surrond sound system, so it's easier for my wife to use the sound system. I put in all the information that it asks for, including the IP address that is...
- Jul 19, 2018No that's a different feature, under LAN Setup add a reservation for the device
Netduma-Fraser
Jul 19, 2018NetDuma Partner
Would just advise setting a static IP for the device then in LAN Setup and that should achieve what you want
G4Captain
Jul 19, 2018Star
Would that not be under the static routes option?
- Netduma-FraserJul 19, 2018NetDuma PartnerNo that's a different feature, under LAN Setup add a reservation for the device
- G4CaptainJul 19, 2018Star
Thanks a lot!
